goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.html
Thu Apr 21, 2005 3:17 pm
OK,
You load the base map, then turn off the ignition, and then start the car..then you can change fuel/timing/misc with it running; you just have to reset the ecu by turning off the key after loading a base map because it throws the car into limp mode temporarily.
I switch back and forth; I'd like to get a serial to usb cord so I could use both at once, but oh well. I just turn off the wideband, then plug in the romulator, enable it, and tune, then switch again.
Nick
