eprom emulator for a rb20det
RBKIDD
Car: 92' RBsilvia
07' TBSS
so i was looking for a real time tuning device for the rb20, so i can get a good dyno tune.i came across on the moates website a little device called the ostrich 2.0.i was wondering if this would be a good thing to use to do real time tuning.if so what software would be best for tuning with it on a rb20det.or if i should keep the eprom and get like the burn2 programmer on the moates site.i would much rather go with the real time emulator if so.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
RBKIDD wrote:so i was looking for a real time tuning device for the rb20, so i can get a good dyno tune.i came across on the moates website a little device called the ostrich 2.0.i was wondering if this would be a good thing to use to do real time tuning.if so what software would be best for tuning with it on a rb20det.or if i should keep the eprom and get like the burn2 programmer on the moates site.i would much rather go with the real time emulator if so.
http://www.nistune.com realtime eprom board no chip burning.
RBKIDD
Car: 92' RBsilvia
07' TBSS
ttt
jey_253
Car: 1990 S13 Silvia Conversion Rb25det
definitely nistune +1
onepuff
Ostrich works good but if you don't already have one I would get the whole Nistune system(board/software). US/AUS exchange rate is pretty good right now i think. Matt provides very good support for Nistune also. He recently found the warmup timing part of the ECU code for the RB20 which causes some weird bogging issues when the engine is warming up. ECU retards timing to 7* for some reason. He tried to help me last year with the issue but never found it til recently. Now that will be able to be corrected in the next release.
TECHLINE08
Car: RB S14
i've been having that exact same issue with the warm up cycle. Glad to see that someone has found a cause. I have search this for awhile now and never found anything. Is this a symptom associated when the nistune or an odd factory program? sorry for the thread jack
onepuff
It's something in the factory code but can now be changed. Check the nistune forums. Matt has a new Nistune mapping guide that you can download where he shows this.
TECHLINE08
Car: RB S14
great site, lots of useful info.
RBKIDD
Car: 92' RBsilvia
07' TBSS
ok so i know im gunna get annoying now. what is needed for the ostrich emulator to tune the rb20ecu, like from soup to nuts.then what is needed fot the nistune? soups to nuts .
Yellow4g63
RBKIDD wrote:ok so i know im gunna get annoying now. what is needed for the ostrich emulator to tune the rb20ecu, like from soup to nuts.then what is needed fot the nistune? soups to nuts .
Install Nistune daughter board into ecu, Consult cable, laptop and nistune software which is very good . When you plug into the consult port with the cable you hit the sycn button in Nistune then when u make a change it's updated automatically to the ecu.
http://www.youtube.com/watch?v=WjQJxWSE ... 6P1d16V5-Q
hope that helps. Once your done with the emulator you have to burn the info on to the chip and reinstall the chip or just drive around with it hanging on top of the ecu.
onepuff
If you install the Nistune board you will not need the Ostrich. To install either one you will have to depin the original Rom chip from the ecu and install the Nistune board which involves soldering it to the board or for the Ostrich you will install a chip holder which will allow you to remove the Ostrich or chip with just a locking lever. The Nistune board will be permanently installed and you can just make ROM changes directly to it. With the Ostrich you can make realtime changes and just leave it plugged in or when you are done tuning, burn the bin file to a chip and install the chip. Then you can remove the Ostrich. I would only get the Ostrich if you were going to tune other cars with it. If you get the Nistune board you have tuning and Consult all in one. It all runs through a consult cable. With the Ostrich you have the USB cable for the Ostrich and a separate cable for Consult (USB or serial cable)
Modified by onepuff at 12:38 AM 3/24/2009
Yellow4g63
onepuff wrote:
If you install the Nistune board you will not need the Ostrich. To install either one you will have to depin the original Rom chip from the ecu and install the Nistune board which involves soldering it to the board or for the Ostrich you will install a chip holder which will allow you to remove the Ostrich or chip with just a locking lever. The Nistune board will be permanently installed and you can just make ROM changes directly to it. With the Ostrich you can make realtime changes and just leave it plugged in or when you are done tuning, burn the bin file to a chip and install the chip. Then you can remove the Ostrich. I would only get the Ostrich if you were going to tune other cars with it. If you get the Nistune board you have tuning and Consult all in one. It all runs through a USB cable. With the Ostrich you have the USB cable for the Ostrich and a separate cable for Consult (USB or serial cable)
Why did u Quote me?
onepuff
Because your info was confusing. If you install the Nistune board you don't need an emulator or a chip.
Yellow4g63
onepuff wrote:Because your info was confusing. If you install the Nistune board you don't need an emulator or a chip.
was in a rush so I just said emulator thinking he would know I was talking about the Ostrich.
onepuff
You just made it sound like you still need an emulator(Ostrich) if you install the Nistune board which you don't.
RBKIDD
Car: 92' RBsilvia
07' TBSS
wow thx for the info! would i need to remove my daughter board?
onepuff
Check out the Nistune website and forums. Plenty of info on there.
