eprom chip?
fabio240
Car: S13 with ca18det
I forgot what member burns the eprom chips. I basically need one that has the z32 maf setup... Hopefully someone can point me in the right direction
mbmbmb23
Im currently working on a chip for another member (if you read this i have not forgotten about you) but I could mail you one after I do his. What is your setup? All stock plus Z32 maf?
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
^^^^ no rush, still waiting for the safc to arrive from japan, and still have to wire it up..... but then i'll be more antsy than a kid waiting for Christmas to arrive! ^^^^^^
fabio240
well my setup when Im done will be z32 maf, walbro pump, fmic, full exhaust, big 16g, 650cc injectors, but when I finally put the rebuilt motor back in and break it in I will need it for stock injectors,z32 maf, walbro, fmic, but the big 16g will be on it but I wont be goin into boost until the motor is broken in.
mbmbmb23
fabio240 wrote:well my setup when Im done will be z32 maf, walbro pump, fmic, full exhaust, big 16g, 650cc injectors, but when I finally put the rebuilt motor back in and break it in I will need it for stock injectors,z32 maf, walbro, fmic, but the big 16g will be on it but I wont be goin into boost until the motor is broken in.
Why not break the motor in with the 650cc's?
dhen
Car: MGA w/ CA18DET
Hi mbmbmb23, I just sent you an email.
Darian
fabio240
Because Im not even gonna have a basic tune for the 650cc injectors so ima do it with the stock injectors and break in the motor.
mbmbmb23
fabio240 wrote:Because Im not even gonna have a basic tune for the 650cc injectors so ima do it with the stock injectors and break in the motor.
You dont need a "basic tune" for the injectors. The ECU just has to know you added larger ones and you have to correct the value in the tune for blast off time (bigger injectors need to open and close sooner...and theres a value for that in the ROM you can change....same as the value for which MAF you have). This can be done at the same time.
fabio240
could you burn me a chip with the z32 maf, and 650cc injectors?
