Eprom chip!
Red93coupe
Car: 1993 CA powered Coupe-sold 1996 Maxima 5spd all black, 1992 300zx all black 2+2 soon to be TT
Alright I found the egay ecu chips but I don't trust them at all....I have heard some guys on here can do it, I was wondering who they are and if the still can preform this service?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
c-rad used to do it........ but not anymore.
I had my eprom done by jestr tuning(C-rads friend) and they did a real clean job.
best1tuning.com does
are you looking to chip your ECU that is already socketed or do you need it socketed too?
Red93coupe
Here comes a dumb question what does socketed mean?
float_6969
In stock form the EEPROM is soldiered directly into the board. Most of the time when you get a chip installed, they will soldier in a "socket" that allows you to quickly remove and install the EEPROM's so that you don't have to de-soldier and soldier in a chip every time you want to change the chip out.
Two-Fortee
Car: 180sx.
float_6969 wrote:In stock form the EEPROM is soldiered directly into the board. Most of the time when you get a chip installed, they will soldier in a "socket" that allows you to quickly remove and install the EEPROM's so that you don't have to de-soldier and soldier in a chip every time you want to change the chip out.
Makes sense. I just e mailed best1 for a quote. I'm assuming its going to be like $300, but it will be worth it. So you guys trust these guys with your tune? Do they usually do a great job?
ca18detgabby
03 Infiniti G35
jestr tuning did it for me for $150. I didnt know much about them but C-rad recommended them and they did a really clean job.
Ca_Silvia
There are quite a few companies:
drdrift.com-austrailianorrisdesigns.com-europebest1motoring-U.S.jimwolf technologies-U.S.
That all i can remeber off the top of my head. If you plan on changing your setup as the years go by definatly get a socketed ecu. Do not ever buy an ebay chip.
Two-Fortee
Car: 180sx.
Best1 wants $375 shipped for mine. $100 after that for a retune. But I think he's installing it with a socket too.
Modified by Two-Fortee at 12:11 PM 3/27/2008
Red93coupe
Well my friend up here is a wiring/soldering guru, he makes his own circuit boards and such where would I find a socket?
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
I can vouch for BEST1TUNING, his work is awsome and his soon to be released inventions for OEM ECUs are rad! I can't wait for him to retune for my new setup T28R+HKS 256s
biosehnsucht
radioshack, fry's electronics, etc, you could order from digikey.com if you can't find any locally
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
I got my EEPROMs and my ZIF socket, chip burner, and even my EPROM Emulator from http://moates.net. You will want to grab a DE-soldering iron from Radioshack, and a good, hot soldering iron as well to install the ZIF socket.
ilovecoupes
Red93coupe wrote:Here comes a dumb question what does socketed mean?
did a quick search this is basicly what you are doing
http://www.superhonda.com/tech....html
