djzteb wrote:Hey selfguided,
looking through this thread and having the same ambitions as fastpathy I was wondering if you know if the bolt patter for the 350Z and the Pathy are the same for the intake manifold. Maybe one could then switch to say the intake manifold off the 350Z or G35 and then to the plenum off one of those rigs as well, then upgrade that setup as they make the parts to upgrade those manifolds and not the ones on the Pathy. Any thoughts or knowledge on the subject?
Thanks
If you compare the two gasket sets that selfguided posted above you can see that the ports are completely different in size and you would probably need to re-machine the plenums just to create smoother transitions. It is too much work for for the minimal gains, that's if it is even possible.
EDIT: There is also the option of having an adapter custom-made (to avoid re-machining the plenums) but that is still a lot of work and will probably be a PITA to make sure you have proper clearances (to minimize re-location of other parts).
Modified by Pwnin O'Brien at 1:02 AM 3/9/2010
