I found an article that answers a few questions that most everyone has had at one time or another. Now, before I go any further with this, let me make one thing ABSOLUTELY clear. I have not been able to verify the legality of the question that this article brought to mind. I am however checking into a few things that look promising. Expensive, but promising. The full article can be found at.
http://www.off-road.com/dodge/...l.htm
Based on my understanding of this article, ANY tampering with the configuration of a certified vehicle is illegal. That DOES include CARB certified parts. This is an EPA (Federal) statute. Now, the article was aimed at emmisions, but quotes the statute from the clean air act, as well as a few interpretations from an EPA official. Towards the end of the article, there is a very encouraging statement; "Specifically, the USEPA has placed the burden of proof on the individual. The only way an individual is absolutely assured of remaining in compliance after making modifications is to spend about $2,000 dollars or more putting the modified vehicle through the full federal test procedure (FTP) that the automakers use." Remember that, there will be a quiz later.
Upon further research, I found a letter from Steve Albrink (USEPA) that stated; "However, while it may be legally possible to insert a newer powertrain and control system from one vehicle manufacturer into and older vehicle or the chassis of another manufacturer, there is a concern that in practice, these types of changes are usually not completed correctly either because of the prohibitive cost or the lack of proper ability or knowledge.... Therefore, EPA presumes this type of engine change to be illegal unles the person who installs the engine can demonstrate that he/she has or will correctly make all the necessary modifications to make the powertrain and control system in the vehicle identical to an appropriate certified configuration."
Now, having said that, (bear with me, almost done) it stands to reason, that although engine swaps (ie. KA to SR) are currently illegal, IF, and only if someone performed the swap, then had the FTP performed and the configuration was then certified, they could then perform the swap in a legal manner with EPA (Federal) approval, having demonstrated that the configuration meets Federal standards.
Before the flaming starts as I'm sure it must, keep in mind that this is currently only a theory that I have developed. I am researching this with the EPA, CARB, and have been in contact with Mr. Albrink to confim whether or not this is indeed possible. I'm sure that should this prove to be the case, the LEGAL method of swapping will remain quite expensive, somewhere in the range of $10,000 including parts, labor, and certification.
Some time ago, I stated that I believed there was indeed a loophole that would allow LEGAL SR swaps. I believe now that I may in fact have found that loophole. Albeit an expensive one, it does appear to at least be an avenue worthy of consideration. I'll keep everyone posted.
By the way, Have any Moderators/Administrators considered a Automotive politics forum? Might be a good idea. Just a thought.
Thanks for your patience, I know this was a long post.
