Eonon touchscreen head unit
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
jdjenkins
Car: 09 Nissan Versa
Does the Versa come equipped with ISO connectors to interface with an Eonon 1012 touchscreen unit, or will I have to buy adaptors?
Codelicious
Car: 1989 Nissan 240SX
Should just be a plug and play if it is an in-dash touchscreen (double din), the ISO cord should fit into your Eonon HU. If your new HU is a flip out touchscreen (single din) you will have to buy a harness for it.
Hope that helps.
jdjenkins
What about the antenna? The touchscreen comes with a female banana plug jack but I've heard that I will need an adapter because Nissan doesn't use banana plugs.
Codelicious
I'm actually not sure, I was looking around for a do it yourself on how to install a stereo into the Versa so I could get you a picture of the stuff back there and was only able to come up with this:
It's from williamk10's carputer thread. Hope that helps.
jdjenkins
Not really, I need photos of the stock HU and factory wiring harness
Shad0wXCalibur
Car: Nissan Versa SL Sedan
Are you asking if you need a wiring harness? If so, then you don't NEED one but it's highly recommended to avoid hacking the factory wiring and to make things easier. And yes, you do need an antenna adapter to use the FM radio on an aftermarket deck.
Edit: I looked up Eonon decks and the harness they use is interesting indeed. It looks like you should be able to cut that plug off and splice into a wiring harness that plugs into the factory harness. I am not 100% sure on that though.
jdjenkins
I've already talked to the local installer and they can fab up an adapter for $40.
Return to “Versa Technical Discussions”
