Entry Exit Mode HELP
danslattery
Car: 2006 G35 Coupe
I have a 2006 G35 Coupe that had the entry exit mode where when you open the door, the seat goes back to let you in and the steering column adjusted and when you closed the door the seat went into place etc. Well Now I dont have it and Infiniti dealer is telling me I NEVER HAD IT!
I NEED someone to tell me their 2006 has it so I can prove to the dealer so they will fix it! They said it was a misprint in the manual too!
HELP!
:frown:
sniper27
Car: 2010 G37 sedan - Moonlight white/graphite
2008 M35 - Moonlight white/graphite
2011 Audi A6 3.0T - Ibis white/black
do they have a 2006 on the lot? i think that is a feature of the premium package. Maybe they thought you didn't have that?
joe603
Car: 2014 Durango R/T
Yes, it was optional. Here is a copied section from the owners manual:
AUTOMATIC DRIVE POSITIONER
OPERATION
The automatic drive positioner system
has two features:
O Entry/exit function (only available on
models equipped with automatic
transmission)
O Memory storage function
ENTRY/EXIT FUNCTION (if so
equipped)
This system is designed so that the driver's
seat and steering column will automatically
move when the automatic transmission
selector lever is in the P (Park)
position. This allows the driver to get into
and out of the driver's seat more easily.
(This feature is not available on models
equipped with manual transmission.)
The driver's seat will slide backward and
the steering wheel will move up when the
driver's door is opened with the key or ignition
switch in the LOCK position.
The driver's seat and steering wheel will
return to the previous positions:
O When the key is inserted into the ignition
switch after closing the driver's
door, or when the driver's door is
closed after inserting the key into the
ignition switch.
O When the ignition switch is pushed
with the driver's door closed.
O When the key or ignition switch is
turned to the ON position.
Initializing entry/exit function
The entry/exit function can be activated
or cancelled by pushing and holding the
SET switch for more than 10 seconds
while the ignition switch is in the LOCK
position. The indicator light will blink
once when the function is cancelled, and
the indicator light will blink twice when
the function is activated. If the battery
cable is disconnected, or if the fuse
opens, the entry/exit function will be cancelled.
In such a case, after connecting
the battery or replacing with a new fuse,
open and close the driver's door more
than two times with the ignition switch or
ignition switch in the LOCK position. The
entry/exit function will be activated.
