Enthalpy tune
esahuque
Car: 95 240sx KA-T, 04 frontier
To start off, I searched and came up with mixed answers
I recently blew my motor. So while I'm rebuilding it with forged internals i picked up a used motor for free. I am going to drop this sucker in hopefully to make a few auto and drift events. My question is: Is it OK to lower my Boost with an Enthalpy tuned ecu?
He tuned my ECU for 12psi, but since I'm putting in a used motor i would like to lower the boost down to 8psi. Will this have any ill effect on my timing? or will my tuned ecu compensate for it?
neverlift
it should be just fine, you have to go past 8 to hit 12, and enthalpy is pretty good, you might need to add a degree or so but it might be spot on. give him a call
480sx
Car: 1996 Pearl White 240sx
Howd you blow your motor with an enthalpy tune?
The tunes fine for whatever psi, i asked him and he tunes the ECU to the max MAF reading all the way down to the smallest reading.
esahuque
failed WG. boosted like 27psi
neverlift
esahuque wrote:failed WG. boosted like 27psi
holy **** balls man thats a spike for ya arse. what brand w/g?
also a maf does not read psi it reads airflow.
WDRacing
Time for an overboost limiter...there's a how to in the FAQ
esahuque
neverlift wrote:holy **** balls man thats a spike for ya arse. what brand w/g?
Crappy *** OBX W/G that was given to me brand new. I now have a new tail 35mm W/G
WDRacing wrote:Time for an overboost limiter...there's a how to in the FAQ
Already on top of that. I read the DIY thread and I'm defiantly putting one in
neverlift
stank you yeah I'm very skerd of them, bought a manifold spacer for the wifes old civic, it fits a sohc better(ka24e sohc that is )
yeah I'll be doing the overboost(not as needed with a t25 lol) biggest spike I've had was like 15psi wastegate line blew off
Florida240sx
I've run 19psi and run 8psi and even had some 25psi moments all good
Jookmasta
yea u will be ok to run lower boost as his tunes have that tuned for. it will modify the timing/fuel to the boost level but it is always best to check them with a timing tool and wideband.
