Entertainment display buttons not lit up
Likwidpink
Car: 2015 Nissan Rogue SL
We just bought a 2015 Nissan Rogue SL and noticed that the buttons(camera, volume, sxm, etc) aren’t lit up at night like say the ones for the a/c gets etc. tried to see if it was a fuse but couldn’t figure it out. Am I missing something? They do light up correct? Odd if they didn’t since it’s impossible to see the buttons at night. Anyone have this issue? Attached photo to show
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Check it for a firmware update, that was one of the "bugs" in the early Bosch navis. To see your version:
Turn the ignition on and the audio off.
Hold down the Apps button and then twiddle the Tune/Scroll knob rapidly back and forth.
Menu appears showing a "Version" button.
If the version displayed isn't D407 or higher, it's buggy and the dealer has a thumb drive to update it. The update takes about 50 minutes plus some screwing around to reset the unit and make sure the repro took, so they shouldn't charge more than 1.5 hours for it. The repro is a good fix, we rarely see any issues with those units after they get the update.
Likwidpink
Thank you! I’ll check that later on today and go from there!
VStar650CL
Technical Expert
If you want to do the update yourself, you'll need an 8GB thumb drive. This link was pirated from a post on another site, but it appears it still works:
https://drive.google.com/open?id=1u60Hg ... pza0LWejwF
Once you download the update to the stick, this bulletin gives the how-to:
https://static.nhtsa.gov/odi/tsbs/2018/ ... 1-9999.pdf
Likwidpink
Thank you!!
Return to “Rogue Forum”
