Double E »
https://forums.nicoclub.com/double-e-u86689.html
Thu Jun 19, 2008 2:07 am
As it moves around freely, is it still allowing navigation through menus?
I'm assuming your warranty is no longer applicable, right?
SO far, I'm of the opinion that the unit can be disassembled and repaired without requiring too much in skills. Download the service manual and see what it will take to remove the unit, then you'll know more about what you're up against.
Typically, with joystick type controls, there's a metal ring or an actual spring that applies tension around a flexible base (of plastic probably). In the effort to make it smaller, it's probably not actual springs, but a ring that can flex. Inside the base, there's the "ball" of the stick and I suspect the metal ring or other device that applies tension has either come loose or the flexible base has been damaged.
A junkyard is the next best option, however not very many M's were made and it will be a needle/haystack exercise at best.
In any case, this is the first I've heard of this happening in my short time here (@ Jan '08)
