The 1/4 run was done at low boost with a T3 but I had a badly slipping clutch - hence the 13.9. The dyno run was done at 14psi.
As for top speed I've had 154mph before I wimped out
(measured by a GPS system).
One thing to take into account is that you measure your power using SAE standards, and this will come out with a figure quite higher than what I would get over here, I've never seen a CA get more than 250bhp (DIN) with A T25 standard or hybrid.
