Enough Power?
240240
I went to a dyno yesterday with my rb20. Wanted to get a before/after figures when I put my turbo kit on. With 3" straight exhaust, @ 10psi I hit 196 RWHP. I thought I would at least hit 200....Any opinions on that?
S13Coupe
Car: S13 Coupe
That's about the same that another guy I know did. I kinda thought it was a little low too.
rb240det
Car: 1991 240sx Hatchback and 1994 300zx
According to everything I've ever researched...that's about what you would expect from a stock swap. That's not too shabby at all.
matt_calgary
Car: 1989 240sx
take your old crap cat out, I had 140 hp with stock cat and stock exhaust. Put in a test pipe and an RS*R exhaust, 220whp on a mustang dyno, something is clogged
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Are you running a stock SMIC?
240240
everything is stock except the exhaust, 3" straight back, no cat
namwons_240
Car: 97' 200sx ser
do u have a cone intake and/or is it clean? did u do a timing check? spark plugs dirty?
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
gotta love straight forward awnsers!!!
matt_calgary
Car: 1989 240sx
Kansei240sx wrote:Are you running a stock SMIC?
I have a FMIC
Joe
matt_calgary wrote:take your old crap cat out, I had 140 hp with stock cat and stock exhaust. Put in a test pipe and an RS*R exhaust, 220whp on a mustang dyno, something is clogged
mustang dynos read a little higher than dynojet
and about 200whp is normal for a rb20. what are you expecting? the engine is dirt *** cheap for a reason
Flicktitty
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
Kamin wrote:mustang dynos read a little higher than dynojet
lol!
240240
one sided FMIC?
SeVa-S13
Car: '05 GTO 6spd
Yeah, not really sure what you were expecting at stock boost on an old *** stock engine rated at ~215bhp....
Carl H
if you are making 180-190whp on a mustang dyno then you are doing good as the motor is rated at 215bhp and if you do the math it works back to be around that at the fly.
Flicktitty
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
SeVa-S13- that is a really good sig about the honda!! LOL!
matt_calgary
Car: 1989 240sx
IMHO, mustang dyno's are correct and dyno jets just read higher. Has anyone had to re-fine tune their engine at the track because it is different on the dyno jet? You'll never have to change anything because a mustang dyno takes into account real-time conditions and calculates them. Not sure what % of a difference is but I've heard about 15% difference between the two. Although heavily bias, the guy at the mustang dyno put it like this
"if you want bragging numbers go to a dyno jet, if you want actual numbers, come here"
Itssorta like saying you have 255 hp ..... but its at the flywheel instead of the wheels, woopy do!
RBTALLY
matt_calgary wrote:IMHO, mustang dyno's are correct and dyno jets just read higher. Has anyone had to re-fine tune their engine at the track because it is different on the dyno jet? You'll never have to change anything because a mustang dyno takes into account real-time conditions and calculates them. Not sure what % of a difference is but I've heard about 15% difference between the two. Although heavily bias, the guy at the mustang dyno put it like this
+1
