enough for my goal?
CA18Fastback
Hey everyone, I was just wondering if you all think this setup will be good for 280-325hp at the wheels. Thanks!
-CA18DET Front Clip-New timing belt-HKS 1.6mm Head gasket-New headbolts(help here, dont know what to get)-APEXi Filter-AfterDark Downpipe-GReddy 19C Turbo(TD06)-MKIV Supra Core w/custom pipes-HKS SSQV-GReddy DD Exhaust-GReddy Profec-B-GReddy Full Auto Turbo Timer-GReddy 52mm Boost Gauge-GReddy E-Manage-RX7 Turbo II Injectors(550cc)-New exhaust manifold(hoping for tubular)-Walbro 255lph Fuel PumpAnything else I will need? I just wanna get up somewhere near 300 before I move onto my Suspension Stage. Also, any other suggestions would be greatly appreciated. THANKS! ~Ian
themadscientist
forgot cams, a set of 264 degree HKS with some new lifters on a ebuilt and tricked out head will help your cause. Provided the bottom end is still tight you should be in the 300hp neighborhood. The stock supra core isn't that efficient though, you might want to look to the aftermarket for your refridgeration needs.
CA18Fastback
well i dont really have the money to do that now. i plan to do that (cams, etc.) this coming fall when I have some more cash and time. what about head bolts? what should i use?
~Ian
themadscientist
OE Nissan is strong as hel, use those.
