enllighten me tell me whats going on
NvS240Sx
Car: 1992 ka24de fastback
okay gusy so im leaking trans fluid wahts up do all 240's have this cuz i was looking under one and it had the same hole where the transmission is but .. it was also in a junkyard lolso whats up guys why am i LEAKY transmission FLUID EVERYWHERE.
JeromeS13
Car: 2008 Subaru Impreza STI
If that's transmission fluid, its probably your front seal.
-Jerome
NvS240Sx
really how much would that cost me u think?
mrzabala
Car: 93 Nissan 240SX SE Hatch
Need better pictures. Whats the smell like? If its strong and nasty its transmission fluid. If not, it could be your slave cylinder is leaking.
Possible leaks:Theres a 1/2 drive nut on the transmission for fluid drain.Slave cylinder sealRear main sealFront cover oil seal (behind the throw-out bearing)And Adaptor plate which holds both halfs of the transmission (RTV on both sides) since it looks like the leak comes from the rear and heads toward the front.
