Enkei 18" wheels on 1997 Nissan 240SX. . .HELP!!
CRyan
Car: 1997 Nissan 240SX
Alrighty, well I've got, as stated above, a 97 Nissan 240SX SE.
I just purchased a set of Enkei RS-7 18". . .7.5" wide with a +35 offset. . .The front tires are 225 while the back are 245.
Here's my question - I've got a set of KYB AGX's and a german made spring for the car that states a 1.4" drop all the way around. Will these wheels clear with little to NO rub?
God I'm praying so -Someone give me some advice on what to do. . .I was kind of in a hurry to purchase a set of wheels because all four tires blew and the stockers are screwed. The suspension upgrade is because the front left strut got a little bent. . .
But as stated above, I just want to know if these will fit and it will be alright to ride. . .
Thanks Nico,CRyan
nismofly
Car: 89 Nissan 240SX Hatch
well you already bought everything right? so you might as well install stuff and see for yourself...it should clear no problem though
yokota180sx
Car: 1997 Stagea RS4, r34 front
mihjt hit your suspension in the front
adrianfromthecastle
Car: 1992 Nissan 240sx
damn dude... buy first, ask questions last
anyways, like Yoko said... you might rub the springs. You might want to consider a 20mm (or more) bolt on spacer to fill the sunkeness
