http://www.enjukuracing.com/products/IS ... 4-S13.html
Product Description
ISIS Performance 5 Lug Hub Conversion - Nissan 240sx 89-94 S13
These 5-Lug hubs are a direct replacement for your 89-94 Nissan 240sx. This is a full set - front and rear. Unlike other 5-lug conversions, this does not need any modifications to the spindles or balljoints. Simply remove your stock hubs and replace them with these.
Specs are as follows:
5x114.3
Front Hub:
* bearing & lightweight designed
* Standard Wheel Studs Mounted
* Compatible with all kinds slotted rotors & spacers
Rear Hub:
* Hub Bearing Inserted
* CNC Machined for precision and accuracy
* Standard Hub Studs Mounted
* Easy Installation - Plug & Play
