Enjuku Racing heater hose install?????
michaelmontuori
Car: 1989 Nissan 240sx SR
i recently purchased the "easy install" heater hose kit for the sr20det redtop for my s13 chassis, how the hell are they hooked up i just can NOT figure it out, can someone post pictures or shed some light on this somehow, ive searched everywhere help pleaseeeeee
Justin35ll
Car: s13 coupe sr20det
The one from the back of the engine uses the U and then a connector to the L and then into the top of the heater core.
Bottom is from the right side of the engine to the lower heater core.
Soo you need 6 hose clamps and one female to female heater hose connector which you can get at any auto store.And you will have to cut them to length
michaelmontuori
these are what i have, i dont have to purchase anything else i dont think
Justin35ll
If those are the actual hoses you got, then idk how to do it.My kit came with a U,L, and S shaped hose
I can't even see those fitting without being cut at least
michaelmontuori
where did you get a kit at?
Justin35ll
enjuku.. or mabye it was frsport actually.
michaelmontuori
i was gonna say i have the enjuku kit, and i figured it out when you said l s and u i i got it, the s is separate and the l and the u are connected all you have to do is bend the one with the black hose thing on it and it fits perfect, woo thanks justin35ll without you i wouldent have gotten this doneee
CMG
Car: 1989 240sx Hatch w/ Redtop
I bought that kit too, does not fit right. I only ended up using one hose, and fashioning the other from oem pieces. The piece with the extra wrapping does not fit without crimping. Just use bits and pieces of bends to make it work.
