If anyone ever has an issue please, just contact us and we can help you through it, some how.
I am going to try to address some of these issues you guys had.
Oil Inlet fitting - with the turbo there should be a banjo bolt and banjo fitting that needs to be used, and not the fitting that comes with the turbo lines. (We ship the Turbo lines in the original packaging, the original turbo lines are designed for a stock T2 turbo and not these aftermarket ones, this is what the other fittings "should" be in with the turbo)
Intake kit - The intake kits are originally designed for an S13 SR stock T25 turbo. On the smaller 3360 turbos they work perfect with the correct coupler. With the Larger 3876 turbos there isnt the same room under there and they need to be trimmed, but do work.
turbo size - The 3876 is a huge turbo for a bottom mount, it was designed for the guy that wanted bigger power on a smaller budget. It does work and can fit under there. As with 99% of aftermarket parts, you need to have good knowledge to be able to make what "you want" work.
ISIS is actually working on a copy of the GT2871R in size (just not ball bearing) Should be priced the same as the others and will just be like doing an install on those. (need a coupler for the front of the turbo and make an intake pipe - we just try to make it easier by including one that can work with the turbo)
We do our best to assemble these kits for people who dont want to go searching for a ton of different pieces.
When installing an aftermarket part - if something doesnt feel right or seem correct, ask someone before doing. (maybe a fitting was miss packaged, or a part was miss labeled, or maybe that is just how it is)
I Personally installed this kit with a 3360 and worked great, and the car is still running over a year later. One of the other guys here just installed the 3876 on his KA and it works very well, just a large turbo for bottom mount.
If you are unhappy with something give us a call and we will do whatever we can to help get you what you want. Just know when dealing with aftermarket performance parts and cars, nothing is like OEM. I have been doing this for over 10 years now and have installed numerous kits on cars. There are some big name brands out there with instructions that still require modifications. It part of the game we all play - called cars.
We sell the ISIS parts because they are inexpensive and very good quality for the money.
Feel free to give us a call or shoot me an email directly if you ever have any issues. -
[email protected]
thanks
Ken
