Q451990 wrote:Wow... visible metal flakes are never good. I'm afraid your guess may be correct. More member will come along soon to comment that may have more experience with this...
Heath
You should have stopped and taken the car to a reputable technician at the first sign of trouble. Driving for months with a vibrating engine is a sure cure for having too much money. The result is what you are now facing.
If you are mechanically inclined, you'll need to drop the oil pan and then the crankshaft, pulling the main and rod bearings, not a fun job at all. CAREFULLY inspect the crank. If it has ANY damage at all, which is likely considering the fact that you have bearing base material floating around in your engine, odds are that your engine is toast. Cylinder walls will be scored and rings will be chewed up, camshafts will be eroded and lifters, valves and valve guides too. All of these damaged parts will contribute even more metal debris as they self-destruct that will compound and accelerate the problem until it seizes up and possibly destroys the block and/or heads, ruining your opportunity to use them to get a core charge back if you get a rebuilt motor.
If on the other hand, the crank journals are smooth and shiny, and inspection shows no unusual wear or damage to the cam lobes or cylinder walls, you may have dodged a bullet. New bearings and rings, as well as valve guide repair will give you more engine life, but it will never be as reliable or long lived as it would have if maintenance had been performed regularly. If this is the case, the block, heads and all components must be reconditioned, properly prepared and cleaned thoroughly, and that means sterile before re-assembly in a clean dust and wind-free environment. Clean all components with kerosene first, then hot soapy water, and rinse well and dry immediately, then coat all parts with oil. This must be done all at one time to prevent abrasive dust from getting on parts and inside the engine, or causing rust on unprotected parts, where it will cause exactly the same problem you have now.
If major components are shot, you'll need a new long block, or a good used motor. If you lack the tools and instruments , and the skill and experience to do this properly, you'll need to have a good mechanic do it for you. Have him replace the motor with a known good used one or remove and re-install all the accessories on a new long block assembly.
Other members may be able to recommend a good tech or business that will treat you right and is reputable.
None of these solutions will be cheap or easy.
For all other new and/or inexperienced members reading here, this is a classic example of how oil is cheaper than parts.
