enigne noise check out
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
hey ya'll check this out. I think it might be serious!!! Ignore exhaust and listen to the knocking
http://s179.photobucket.com/al...7.flv
what could this be? lolI went for 1 drive and came back with low oil and next to no anti freeze, had a big leak
nissanfanatic
Car: 1992 Nissan 240sx SE
Its rod knock..
1995240sxSE
I know, sucks huh just got it running!!! Could I just put new rods in???
nissanfanatic
Just buy another running KA.. Cheaper and less work.
1995240sxSE
i have been looking cant find harldey any around here. shipping is killing me for freight! I could in theory... remove engine, pull oil pan, remove crank, pull out all rods/pistons. replace rods. then put back togother. right, with out having to pull head apart? rebuild from the bottom.
nissanfanatic
Probably not. There has obviously been some metal to metal contact that resulted in excessive wear on either/both the crankshaft and rod.. The rod may be out of tolerance and you will need to undersize it and run oversized bearings..
Keep looking for a used KA.
And you will have to pull the head off...
KATwo40
Car: 1993 240sx KA-T
Totally with Cory on this one. Find a used engine and rock on.
Riubens
Car: ka-t 240 and 99 Q45 t
my old engine did that same sound but not that loud , my ka had 242k miles,I just went ahead and bought a new ka with 150k miles and went ahead and changed the valve seals and the main seals, compression 165 all across. believe me those things go out quik.
