Why do you say that? It will be a catless system. Just using the stock 2.25" piping from where ever that 3" pipe ends. I think it would sound pretty good actually. Not to loud but you will still be able to hear the exhuast.c-rad wrote:Using a stock catback with a 3" downpipe is worse than using a stock downpipe/catback.
The 3" to 2.25" transition is pretty steep. It would be like trying to blow through a coffee straw.driftin8nez wrote:Why do you say that? It will be a catless system. Just using the stock 2.25" piping from where ever that 3" pipe ends. I think it would sound pretty good actually. Not to loud but you will still be able to hear the exhuast.
Also the oem exedy or seco are no good?
Hold up--- My mistake- CA18DE clutch is too small. Just get a KA24 clutch. Removing the alignment pin from the flywheel takes about 30 seconds.driftin8nez wrote:Ok let me see if i can find it. The one for the ca18de should hold right? And i wont have to mod the flywheel. Sounds good to me.
lol.. I just found the right one to.http://cgi.ebay.com/ebaymotors...46603So just go ahead and buy the ka24de clutch kit. I think i'll go exedy. I should be able to hold seeing as the stock torque on the ca18det and ka24de are about the same.c-rad wrote: Hold up--- My mistake- CA18DE clutch is too small. Just get a KA24 clutch. Removing the alignment pin from the flywheel takes about 30 seconds.
Is there anyway i can get a couple lbs. shaved off the stock flywheel?tyrannix wrote:while youre in there, you can get a jun 5.X kg flywheel from rare trick http://www.raretrick.com/index...=6004
$350 + shipping, ends up being around $380 shipped
it might take a bit for you to get it, as they will probably have to wait for their next shipment after your order for them to ship it to you (expect a month so you wont be dissapointed)
them and a store in the UK are the only ones weve found that sell new light flywheels for the CA
CJ
driftin8nez wrote:Is there anyway i can get a couple lbs. shaved off the stock flywheel?
No, the SR's can use a Maxima clutch. And yes, the KA24E and KA24DE clutches are the same. Look up a centerforce dual friction. It will say 89-98 240SX. Or it will break it up into 3 parts- 89-90, 91-94, and 95-98. But they all have the same part number.Kouks wrote:Dont Sr clutches work on KADE? thats why people buy Daikin(exedy) clutches for the DOHC.
Are you serious? Go back to the hole you came out of troll.1via wrote:If you plan on going cheap dont do the swap at all. Get what its suppose to have. Ka clutch and remove pin. GET A 3 in. CATBACK. Let it breath right.
dattodude wrote:For the clutch, a Heavy duty organic sprung center Exedy/Daikin will do the job well. If you are into drifting, then getting a button clutch to pop the wheelspin into action is good, but it's not real easy to drive in traffic, and if friends (or girls) drive the car, they'll have trouble driving it unless they are car fiends like most of us here.
We don't need to dig into the KA spares box here in Australia, but it's good to know they are a close match.
Chris
I already bought an XTD Stage 2 clutch that holds about 260 torque for 141.00 shipped with pp/ t/o bearing/ pilot/ and align tool. Hope all goes well. But those clutches are good to know about.Kouks wrote:ACT makes a Xtreme Street Clutch with uprated pressure plate, (holding 333tq) performance organic disk for the ka, 409 from enjuku. Looks like a streetable clutch.
