MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Mon Dec 20, 2004 2:46 am
Of ALL the pictures of Alyx, you had to take one while she looks like she's got to take a ****.
Boy...you Nvidia people...
And have you tried using the sawblades on anything other than zombies? It doesn't cut them in half! Pissed me off. I carefully carried one through radioactive sludge, accidentally killed an NPC, and when I finally got to use it, it just knocked him backwards.
Oh, and if you've finished the game, you've GOT to play through the whole thing again with the grav gun the whole time. You have to start after you get the suit, though, or it ****s things up. And you have to skip the grav gun training map, as you can't pick up Dog's ball with it. For some reason it just makes lots of duplicates of it. Actually, it makes duplicates of ANY NPC except Barned or Alyx or the other big main ones. If you try to "grab" or push a resistance member, it just makes a copy that you grab or launch, and the original is unaffected. Really wierd. Fun as hell to turn up the maximum capacity of the grav gun and toss shippng containers at combine.
Oh, and I don't know if you've done this yet, but since your machine can handle it, enter into the console cl_ragdollcollide 1. This will make the ragdolls have physical presence, and stack and not go through walls and such. Makes a BIG difference in humorous death positions.
EDIT:I just noticed blood on the console on the bottom right corner of the Alyx picture. What the hell did you get blood from at that part of the game? (That's right before you get on the elevator for the final sequence, right?)
If you don't know how to get the blue grav gun early on, do this:
--from the main menu, hit ~.--enter "map c3_citadel_04" (I think, the console will offer suggestions, so you'll know what I mean)--Then wait for all the weapons to get picked up. Make sure you have the blue grav gun, --then enter into the console "changelevel [mapname]" choose any map. To get a list of maps, type "maps *" or just start typing a name in the basic format of C3_citadel_04 and you'll get suggestions.--when you get to the new map, type "impulse 101"you now have the blue gravity gun.
--Remember, having the suit on already at the point where they give you the suit ****s things up (not bad, but you can't progress). Just do changelevel (NOT map, that resets the entity list and you loose the grav gun!!!!) and skip to the next one. --Also, you must changelevel at the grav gun training grounds, --and at Ravenholm, when Grigori tosses you the shotgun, you must take at least 1 round from it, so fire a shot off if you already have it, and then get a round from the one he tosses you, otherwise you can't move on.
And finally, to change the max capacity of the grav gun, use "physcannon_maxmass ####" The default is 1500, and you can list a default value by entering a command without a value, in case you forget. Turn it up to 10000 and you can lift anything.
BE CAREFUL LIFTING THE BUGGY AND COMBINE APCs. For some reason, this causes the game to slow down to about .25 frames per second (yes POINT 25) on my roommate's computer. Then when you let go, the thing just spazzes out and shoots around through the air and on the ground, and in the case of the buggy, you can no longer drive it. I don't know if your system will do this, but the one I use does, so I figured I'd warn you.
Modified by MinisterofDOOM at 6:04 AM 12/20/2004
