ok having problems with my 89 coupe has a sr20de swap in it.i was out doing figure 8s then it shuts up first i noticed the ignition fuse blew so i just swap one out next to it
then i tired to start the car all i got was the click as if you didnt step on the clutch.then i took a look at the fuses on the kick panel and fuses 20A on R/C Mirror was blown or i can say it was the 5th or 6th on down on the left row that blew and when i replace it , damn thing just blows again and the batter is also relocated to the back and the starter wire is connected to a amp connector the starter dont kick or anything but i checked it so see if it still works it spins and all..well if you guys need pics ill post some up today ireally need some feed back ASAP only car i have and need it to communte if not then ill just get on my skateboard.thanks.
