Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Mon Jun 13, 2005 4:06 pm
Start by checking the electrical system. Check your relays. Check your cabling. Turn the headlights on and have somebody watch them while you try to start the car. Bad battery they will go dim and your starter will click or chatter.
Once you eliminate an electrical problem, examine the starter. From there check all associated hardware.Good luck.
