Engine won't start. Just Cranks.
S13_Thrasher
Car: s13, corolla
I removed the distributor when i was working on my exhuast manifold and now it won't crank over. I set the timing on the crank pulley and distributor before i put it back in but still nothing. I need to get it started soon. Any help would be greatly appreciated. Thanks.
240crazy31
Car: 1991 240
did you line up the mark on the distributor housing with the shaft pin or the mark on the shaft. the mark on the shaft is a little dot. if you lined it up with the dot then it is off you need to line it up with the shaft pin.
S13_Thrasher
Car: s13, corolla
nope, it's lined up. also the crank is set top dead center on the compression stroke.
