I had my '91 KA24DE started and running last week and even drove it to the muffler shop for an exhaust pipe and drove it back. It ran but the timing was a little off and doesn't stay well on idle, although it was running smoothly on parking with 1st gear. The engine has oil and other fluids such as coolent and power steering are full too.
I pulled out the distributor and tried to do it once more like I did before using this manual.
http://www.nicoclub.com/articles.php?id=161707
I set the #1 all the way to the top. I line up the groove and notch on distributor. I made sure the rotor was on position at #1 and the plugs were put in their own place. (1,3,4,2 counter clockwise). There was fuel and the fuel pump works.
The engine won't start (turns but no ignition) after I did the adjustment again. It had a bang in the exhaust when I kept turning. I re-did all the timing again. and there was just another bang again. Now at this point I was really worried.I started checking all the connections and even swapped the ignition coil, MAF and distributor from another '91 model that was running. Nothing changed. Engine still won't start and all I could get most was a 'Poof' flame noise from the manifold. (I got smart enough to not make a bang')
I'm on a very limited time and budget so I can't really afford to tow to a mechanic. I don't even know how much they'll charge me. So could someone please give me an idea on what I could have been doing wrong? I did get the engine running before on the same procedure. Why won't it work again?
Modified by Soravia at 4:42 AM 3/28/2007
