OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Sat Feb 01, 2014 7:52 am
My local Infiniti mechanic replaced the 99 Maxima engine with one from a 95 (rear-ended total) with 73,000 odometer miles (possible). It starts up and runs however we can't get it to idle. It runs fine over 1,000 RPM. When we release the gas, the settles down and dies. We've replaced the MAF with a known good one, installed a new IACV, The EGR was cleaned in the old engine just before installation. New plugs fuel filter and more. We used the fuel rails and injectors from the old engine since they were know to be good before the engine swap.
This new engine has the following (wet) compression readings:
3 cylinders over 142 lbs
1 cylinder at 140
1 cylinder at 110
1 cylinder at 100.
Will these compression readings keep it from idling? It may not idle the smoothest with those compression readings, but would it die?
All the vacuum hoses have been checked.. Vacuum readings appear ok.
Could this be from a bad EGR or fuel pressure regulators?
