silverkaturbo »
https://forums.nicoclub.com/silverkaturbo-u78267.html
Mon Apr 18, 2011 12:21 am
Can anyone point me in the direction of what I should start testing. Ive checked with my volt meter and the battery has 12v off, and 14v while running so its not a battery or charging issue I guess. I've checked all grounds and the connections at the starter several times, even tried adding extra grounds and power cables with no luck anywhere. Ive had my battery in the trunk for the past couple years without problems, but I went ahead and put my old slim battery I was running before back up front too just to make sure Im supplying plenty of power.
I hate electrical problems. So where should I go testing from here?
