elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Dec 19, 2005 5:05 am
One thing I like is on heavily greased areas, is brake parts cleaner... it really cleans stuff good (it really eats through stuff, trust me)..... ONce you get all the heavy grease off with that, apply some simple green by spraying it full strenght over the engine bay... A gentle mist over everything will do it...
it is really helpful if the engine is warm when doing this..... it helps the water evaporate so it doesnt get where its not supposed to!! ..
Finally, I then hose the engine bay down with a gentle stream of water..... nothing extreme, NO PRESSURE..... just a nice gentle rinse to wash the water away..... Once its all rinsed off, you can take a leafblower to it and dry it that way, or just take the car for a 10-15 min drive... The engine being warm + the fan will dry it sufficiently.....
After that is finished, take some plastic care stuff (armor all is too greasy IMO) and spray it on... all done!!
