Justin88na »
https://forums.nicoclub.com/justin88na-u143076.html
Sat Nov 14, 2009 4:53 pm
Hey guys,
So I am running into an engine vibration issue and need your thoughts on to what it may be. I have been racking my brains and searching but havent found anything that is exactly the same as my issue.
I really have two issues:-Rough idle-At speed roughness
I have already cleaned my MAF and have recently run injector cleaner, engine flush, new oil, and K&N cone filter. This reduced the idle roughness, I would say it reduced ~50%. However at lights I still idle like I have aggressive cams, very lumpy.
Once moving, it happens again but only in a small RPM range. At speeds around 40-50, when cruising, I will give it light throttle, between 1/8-1/4 throttle, around 1800-2000rpms it will vibrate again. Now this is a more of light shaking than a actual vibration. Once I get it above 2000rpms it goes away and is fine.
I still have yet to clean the Idle Air Control Valve, but before I did, I wanted to get opinions on what the issue may be, so I can tackle it with some direction.
I read somewhere that our crank pullies are adjustable with weights to perfect the balance, maybe i lost a weight? There is some lateral movement with my fan clutch(the blades/fan assembly) could it possibly be this? I really am at a loss.... Please, someone give me some direction.
Modified by Justin88na at 7:28 PM 11/14/2009
