TachyonS14 »
https://forums.nicoclub.com/tachyons14-u10260.html
Sun Oct 26, 2003 12:25 pm
Alright, heres the deal... I have a 97' 240 and I am getting an engine vibration. When I first start up the car, you can't feel the vibration because the idle is kicked up because it's cold, but once the engine gets warm the vibration becomes very noticeable and the steering wheel shakes violently. But, if I turn the a/c on, the vibration is slightly there, but very hard to tell. Same goes for driving with the a/c off, It's really only noticeable when sitting at a stop light. Once I get off the line it's hard to notice the vibration.
So, I've taken measures to get rid of this problem. I've changed my spark plugs, and plug wires (factory ones), left, and right motor mounts (factory), PCV valve, and cap and rotar. Whatever I do, I just can't seem to get rid of this problem. I've been told to clean my throttle body, haven't done that yet. Maybe a butterfly valve isnt opening? Also, this may give some insight to the problem... When the car is warmed up and I have the a/c on, if i turn it off while at idle my rpms with drop to around 300-400 almost stalling the car then it will jump back up to where it's supposed to be. Maybe have a valve job done? I've checked my timming and it's set at 20 degree's... Also I've been told to un-plug my TPS sensor and then adjust my timming accordingly... Can someone show me where the sensor is? My chiltons sucks.. Thanks for reading, any and all suggestions are welcomed.
