Mine does the same thing, especially cold. It seems to me the computer changes the timing and maybe the fuel mixture too at curb idle but I'm no expert, I have the TBI (Z24i). As you say with just a little increase in RPMs it smooths out, so I have decided to not worry about it. Motor mounts could be a issue. I'll check mine.pvtdiaz wrote:Hello everyone I'm new to the nissan pickup scene not used to all the import things on the truck I have a 86 nissan 720 4x4 that seems to run fine except the engine vibrates or shakes at idle only once u run it passed 5mph it stops any clues carb is rebuilt vacuum lines are fine I just did the oil change,oil filter, fuel filter, plug wires, spark plugs, coils
