engine upgrade for DD/ what should/can i do for $2500
khon240sx
Car: 1989 240sx coupe
currently have a SOHC and it's about to die. all the oil went to the radiator :facepalm:
i need the new engine for my DD for now..... track later.
I need your opinions from you guys. :ohno:
:::: this is not i really want to do (SR20 swap) but i want to know if it's possible with $2500. everything is stock except inter-cooler and rad from ISIS. :::
1: buy a KA24DE motor (bad rings) and rebuild it. rebuilt kit quality = sightly better than OEM. have some $$ left and goes toward the suspension upgrade.
2: buy a KA24DE motor (working condition) drop it in my coupe and drive it until i have enough $$ for SR20 swap.
labor? I will do all this by myself.
thanks./// :)
khon
Morph
Car: 91 Sr Powered Coupe
Option 1, depending on the rebuild kit...
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
just save more money and get what you really want
neverlift
option 3 would be to replace your headgasket on the single cam..
or option 2a
get running ka and boost it. You might forget about an sr or will be able to hold off longer so you can really get what you want.(running ka down here goes for less than 600bux)
option 2b
running ka and most of the suspension you plan to get.
option 4 buy a running sr for 2500bux.
Fenris
Car: 2011 Subaru WRX
1989 Nissan 240SX
A CA18 could be certainly gotten on the cheap, plus should be okay on gas for a daily.
xX RB Xx
Car: SE3P, FC3S, FC3C.
Just buy a used ( running) and swap it in. Drive until the world ends.
slipnslide88
Car: 97 VH45de Kouki
SR does not equal a good DD especially with your limited funds. go dohc and deal with it
slipnslide88
cjmirabal1
Car: Past: 90' S13 fastback
CA18DET powered
Current: 90' S13 fastback
Vh45de powered
Fenris wrote:A CA18 could be certainly gotten on the cheap, plus should be okay on gas for a daily.
can deff do a ca18 swap for under 2500! im glad i went that route over an sr(not sr bashing)
