M4T5 »
https://forums.nicoclub.com/m4t5-u123303.html
Thu Feb 26, 2009 7:14 am
Maybe I didn't follow your question as well as I thought I did. Are you talking about the engine cover that bolts on top of the engine under the hood, or the lower engine cover that is located directly under the engine?If it is the actual bolts you are looking for....you need to get them from the dealer.At that point, if I were going back to the dealer for these items....I would definitely make them replace the bolts and get your next oil change service for free. Showing them you are very unimpressed with that kind of service you previously received can get you free service sometimes. At minimum make THEM replace the bolts and any damage to the cover!Don't let this slide because that is just pure carelessness on their part since they do oil changes on these kind of cars with the cover everyday.
J
