BrandAidDesignG35 »
https://forums.nicoclub.com/brandaiddesigng35-u84960.html
Wed Apr 22, 2009 9:08 am
When you installed the filter, did you install it too tight on the intake tube? If there isn't sufficient air flow, it could be robbing the engine of oxygen, it may barely be running, double check this when you check your MAF. I installed a foam filter, and experienced very rich, rough running symptoms... so I took it off.
You could also try re-installing the old filter just to be sure. Good luck with your dilema.
