tuning for power AND reliability varies for EACH motor and it requires experience so ONE DVD alone is not enough. this was a strong point of discussion throughout the production1.8turboterror wrote:Would you say that someone who is pretty computer savy would be able to jump in their car on a dyno after watching this dvd and give their car a basic tune confidently does it break it down step by step for the novice??
thank you,1.8turboterror wrote:Yeah i watched the teaser video it seemed interesting I think I will be buying my copy shortly
good question,do you know how to read the data logs?1.8turboterror wrote:Actually yes I have a ques. I hope its not a stupid one ima tryin explain it as best I can Ok say im in the fuel map the bottom line is the rpm breakpoints and the vertical axis is Load breakpoints in kpa so is it pressure Or just give a a brief explanation of how you would know which cell too fill in for load . I get the Rpms . and I knw how to highlight the whole colume or row or even table to plus or minus fuel . Im just not understanding how do I knw which cell to go to individually based on Load . I hope you can help thank you .. Im ordering my video later today by the way.
please watch the data logging section on the trailer, starts around 45 secondswere you able to read the corrections as you scrolled across the log?you can call us on Monday during business hours if you need help1.8turboterror wrote:No im not familiar with data logging ok I just opened up my aem data log to mess with it tell me if im reading it right ok I chose 3 plots engine load vs. engine speed vs. AFR now as I drag the vertical line across the recorded data by the way I am just using the AEM Sample data log right now my lap top is broke nd cant data log my car at the moment. Ok so on the top right it displays the rpms , afr , and engine load and based on the load at that rpm whether it may be an afr too rich or too lean that how I would pin point that cell ..... Please correct me if im wrong I am extremley interested in tuning AEM and that was my first time ever going into the aem data logger.
