engine trouble
rrocket
Car: 94 Q45 90 300ZX TT
feels like an injector is blowncodes 43 and 51 come uphow do you tell which injector/cylinder or do you have to read 'em all?
goody90q45
Car: 1992 Infiniti Q45 (sold)
You need to ohm your injectors. It can be done in about 5 minutes with a digital volt meter at the harness connector on the PS of the engine. A good range is 10.0 - 14.0 ohms. Following the instructions posted below, check them hot and cold and get back to us with the results.
http://www.q45.org/ohminjectors.html
Good luck
rrocket
groovy.... Thanks
rrocket
advice worked well#5 injector is shot
rrocket
whats the deal with "color coded injectors?'aftermarket here in town guy quoted me $450 I nearly !@#$ my pantscalling nissan in the a.m
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Better yet, call Joe.
http://www.everythinginfiniti.com
Rex
Car: None
Have your o2's been replaced?
And OEM injectors are going to serve you better, unless you need to go higher flow for BIG HP mods.
The OEM injectors should last longer (depending on gas quality) and require less labor long term to replace again.
