I took the car out today and on the way back I fired her up and I barely made it back home. Ran rough like a cylinder was not firing. I pulled each spark plug with the engine idling and no change when I pulled plug #2 (2nd closest to the radiator). Big change when I pulled all the others. So it’s something with cylinder #2.
I changed the sparkplug with #1 but got the same result. So my question - what would cause such a sudden change? I feel like if it were valves or pistons it would have gotten worse gradually. When I pulled the plug wire from #2 I could hear an intermittent ticking. The oil looks fine and there was an odor of fuel with the plug wire out.
Injector perhaps? Are they interchangable with each other?
Thanks guys. This is NOT the way I wanted to generate more traffic to the vert section.
