Engine trouble on an 07' Hatch 41k miles
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Althalus
Car: '07 Nissan Versa Hatch SL CVT
So I go to work at 11am Sunday and leave work at around 930pm and I turn the key and car take FOREVER to start.
Once it does start the RPM and gas level gauges take another couple seconds to come to life.
Anyone else have this problem? Sadly I'm not under warranty anymore so hopefully it's something simple!
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
If you're at 41k miles then you still have plenty of powertrain warranty, it doesn't run out until 60k miles or 5 years.
steed77
Car: 09 Versa Fresh Powder Sedan 6speed
I would check the fuel regulator.... seems like a typical slow start symptom.
Althalus
Took it to PepBoys and they said that my battery was charged 100% but it had low crank energy. Said it was supposed to be around 460-500 but was at like 210. Could this be the trouble.
biggie
Low cranking amps could be the issue, battery could be damaged somehow.
Return to “Versa Technical Discussions”
