IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Mon Jun 28, 2004 1:27 am
i dont know why you would want to replace the 5.6 with the 3.0 diesel.
you would need the motor, transmission, ecu, all sensors, wiring harness, its transmission.
you probably going to have to remove all the wiring from the VK56 and its auto trans from the armada. you going to have to have motor mounts and trans mounts custom fabricated to bolt the motor in. the wiring for the diesel needs to be run in the armada.
your also going to need a driveshaft and entire exhaust system custom fabricated.
the 4 cylinder 3.0 diesel is also only 160hp, 261 lb/ft torque.
the VK56 is a much better engine. 305 hp, 385 lb/ft torque.
