ESFITNESS »
https://forums.nicoclub.com/esfitness-u226354.html
Thu Nov 07, 2013 2:10 am
ughh....
well, I started the car to go home tonight, and put it in Reverse and felt it engage, then drove across the street to Walmart to buy a thing of Lucas transmission Fix.
the car didn't seem to have "power" when I stepped on the gas, but at least the revs weren't jumping.
made it to walmart, got the stuff. started to put it in the transmission fluid filler but it was dark and I didn't have a funnel or a knife to cut the tip of the Lucas stuff, so I only got a lil bit in.
then got on the freeway, it seemed fine, although a lil slow.. smooth shifts, got up to 70 and the car was 'normal'.. then after about 5mins on the freeway, I felt a 'clunk' and saw it had downshifted or shifted out of Overdrive and my revs were holding steady at 3200 at about 65/70 (with cruise control on). I turned cruise control off and tried clicking the Overdrive On/Off button but nothing happened.
got to my exit and stopped at the light. light went green and I hit the gas and the car just revved and barely moved.. I made the turn and got about 15ft and pulled over and hit the Hazard Flashers. put it in park but didn't feel the transmission engage or disengage. no neutral, 1st, 2nd, drive, R... didn't feel anything engage.
i put it in park, turned off the engine for about 5 seconds, turned it back on, put it in Drive again and felt it engage and hit the gas... it moved, but barely... got to the next light (downhill helped) and stopped again. again, hit the gas and didnt' move.. engine reved, but no movement. so i turned it off and on again and finally it engaged Drive and i limped home... not without having to turn it off and on two more times to get the transmission to engage.
this sucks. my only other car is a 99 mustang with a bad water pump that will nearly overheat after about 15mins of driving (which is why i bought the 99 Q45t). and i gotta work tomorrow at 1pm until midnight.. so getting a ride home is gonna be a problem.. and walking 8 miles home is gonna suck (15min/mile walking is 2hours.. i'll get home at 2am.. and it's cold in the desert at night. lol)
could it be a transmission pump problem? a filter problem?
the car moved "ok" when it's just started, but after it warms up it slips and disengaged like crazy.
when i got my headlights changed Tuesday i sat out by where the guys were working on the car and saw they had 3 guys standing over it looking puzzled, and i heard the shop manager say "well, we'll just cross our fingers... " before shutting the hood. i thought what the heck is he talking about? how hard is it to change out a HID bulb? why are you gonna cross your fingers? then when i got home i noticed a couple dents on my hood, one right above the drivers headlight... so i figured THAT must've been what they were talking about.. crossing their fingers that i wouldn't notice....... but could they have done something that would affect the transmission? anything? short out a solenoid when disconnecting the battery? (it also required removing the airbox/intake.. I haven't thought to check the sensor on my airbox yet.. just to be sure it's connected) my CEL hasn't come back on.
i'm stressing out over this.. being a grown man borrowing more money from my dad is NOT what i'm looking forward to.
ESFITNESS on Thu Nov 07, 2013 3:30 am, edited 1 time in total.
