vq35 »
https://forums.nicoclub.com/vq35-u60447.html
Sun Apr 01, 2007 4:52 pm
To start with, i am a new 2001 se manual blk owner and have always owned bmws etc. i ended up having to settle 4 a 4x4 (family etc) and after ltd research found the se manual 2 b the truck with the best specs-waited n found one in seemingly good shape and secured it. now, i have not experienced trucks b4 and am not sure if the 'feel' is right or wrong.the point is that when i am accelerating i am usually holding the shift knob awaiting the shift to second etc and what i found was that i could feel a lot of vibration as the revs climbed and a slight hiccup from about 3500rpm to about 4k and then continued vibration to cutoff of approx 6500(like it plateaus for half a second which im assuming is the vvt kicking in?) -the thing is i am used to smooth revving to redline (in my 99 318ti for example) so the question is that i dont know if this is normal in a body on frame or if indeed there is a problem tha needs to be addressed????
the remedies to my thinking and also from the research i conducted on this here forum is as follows:
1 get new engine n transmission mounts - $$ anyone? w/labour
2 me coils r gone or going and the plugs need replacin (which i am scared to do- not to upset the coils into getn fried) $$w/labour
3 diff problems! the original owner had to fix a leak they found to have contaminated the rear right drum- solution-they 'fixed the problem which i assume required gasket replacement and thus taking it apart and hopefully putting new oil in there and simply cleaned the drum- dont know how to confirm this myself so any advice other than check to see at the rr for any oil, as i have done that and continue to check daily, would be greatly appreciated- also i have noticed taking corners and accelarating that theres hop (not only 'hop' as per non independent rr susp i assume) but also a lil grinding for a quik sec - and this when taking the corner harder (i push to see limits in a safe manner) anyone on spot on symptom of rr diff failure/imminent failure of man 4x4 se ???!!!???
otherwise, assuming a lil ruffness is ok, the car is a fkin thirsty blast to drive and accelerate-it has low mid and top end to boot (although top end could use a lil more which i am sure the g35 man w 298hp solves, i am also wondering if its possible to 'upgrade' via head xchange etc to either the 280hp from the g35 or even the 298hp 2003-2006 ???? i wouldnt care about losing a lil low end
plans for this se include 2" lowering from 4x4parts, rr ltd slip diff, shox(i wonder if bilstein makes f/r or anyone has adjustable ones f/r??!!!???with the 2" drop, how is ride handling and comfort level?? is there a way to retain stock or better(ie plush ride vs bouncy/hard) and still drop 2"??? anyone dropped their se and what were the day2day results????
ps saw today an se with dual exhaust(on either side) and the sound was incredible(absolutely robbbed by the auto shift sequence - woulda sounded nicer in a fkin manual with a well versed driver) pulled beside the guy n apparently he had it customized at hot rod scott thruway muffler (north of queensway on kipling in toronto) think i will pay the man a visit this wk
thanks for ur patience and any help would be appreciated
