Like I said I ordered my torque dampener from Project Silvia and with the item came some instructions. In the instructions was a picture that showed the dampener installed with a strut bar. So take that for what it's worth.rudee023 wrote:BTW the stock upper strut mount bolts aren't long enough to run both a strut bar and the damper?
dj_lennon_franz wrote:yer strut tower is fine...ive seen quite a few drift cars without front sturt bars (the turbo was in the way) and theyre fine...go with the engine mounts for now...youll notice a HUGE difference in the way the motor acts under higher rev drving...there is a company in japan making mounts that are pure polyurethane instead of half poly and half liquid (like the nismo mounts and nissan mounts) if i find who makes these i will post up the company and where to buy em...ive seen em on ebay ONCE so they are quite rare in the states...supposedly they are 50% stiffer than nismo mounts
it would take someone 5 minutes with a welder to fix that problem,if you don't know anyone you would pay at the most 20$ to weld the damper bracket to the STB's bracket.dj_lennon_franz wrote:you CAN install the dampner with a strut bar...however the bolts will be REALLY short...you wont have alot of thread to mount the bolts to...if you have aftermarket camber plates with longer mounts then you will be fine...i could only ever get 2 outta the 3 bolts back on with the stock upper mounts...i dont recommned doing this as you will catch alot of **** for it at driving events from the people who inspect your car
