cuzinyung »
https://forums.nicoclub.com/cuzinyung-u26431.html
Tue Apr 12, 2005 7:56 pm
Buying my 1990 240sx used at 160k miles, I hear the ticking and assume right off that it must be the timing chain. Crap. So what do I do? Try every cheap fix I can in hope that it's not the timing chain.
After doing all sorts of other maintenance, I read about checking the exhaust manifold bolts. Sounds easy enough. One look through the heat shield tells me right off that I'm missing at least two bolts. Alright. So I remove the heat shield and it looks like this:Missing 4 bolts, huh? With little daylight left in the day, and without any extra bolts on hand, I decide to just shift around the bolts that are left, (well I was lazy, so I just moved one) as to evenly distribute the weight:I start up the car, take it for a ride and.... THE TICKING IS GONE!!!!!!! A definite first thing to check before diving into a timing chain job, especially since it seems common for these bolts to mysteriously fall off. I have a new felpro exhaust gasket ready to go, and I still need to get 4 more replacement bolts, but until then, I'm just glad I found the source of my ticking troubles.
