engine tic?
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
sounds like maybe a stuck lifter, i just bought a bottle of engine restore hoping that helpshas anyone used this stuff before? good or bad?oh and the car is a 93 5spd, just bought i hope this isn't anything serious, funny how it was completly quite prior to the sale and only after a few hours of driving i start to hear it someone please help! and keep my faith in these cars!
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
wow, i've been searching and there are just so many things it could be.i can't hear it while driving, only outside of the car when it's idleing, definetely coming from the motor not out the exhaust or anything,from what i have read when you hear it out the exhaust it is a lifter?what is the worst possible case here?
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
ok after even more in depth searching, most likely it is just the timing chain?and that's okay as long as it doesn't continue to get much louder?if anyone can confirm that would be great!i guess i am just used to ohv domestics, when you hear a tick it is a lifter, so from what i hear the sound i am hearing is pretty much normal?
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i'm gonna have to go out on a limb, unless you just wanna keep talking to yourself...
the KA injectors are very loud, quite loud, and they do, to some folks, sound like a bad lifter
KA's are solid and shimmed, so it is possible that maybe a shim is out of spec, but i hardly think thats true
the nasty timing chain noise you are refering too sounds like a very hollow noise. Think like someone trying to drum roll on your valve cover, because literally the timing chain hits the valve cover. If you wanna see if this is true, pull the valve cover off and you will see a very clean and scraped part where the chain is hitting
the only rebuttle i have to my own comment about it probably being the loud injectors is, unless you have your mechanical fan removed it is a bit difficult to hear the injectors.
its just so hard for people to describe sounds your car is making in terms of problems
if you're worried about timing chain check the valve cover and you'll know
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
very good, thank you much for letting me reply to someone other than myself, i will definetely have to take that there cover off
