Engine temperature - 2007 M35X
Bruneieddy
Car: 2007 m35X
Hi,
Can anyone tell me if they are have an issue with their engine temperature? About 3-5 minutes into my drive, I noticed my engine temperaure gauge moving slowly but surely up to the "top" but then will settle back to the "middle."
Thanks
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
are u saying it overheats then moves to normal
Bruneieddy
Car: 2007 m35X
The needle moves creeps to the top and then drops to the middle/normal range.
The00Dustin
Car: 2006 Infiniti M45
Not an expert in the area, but I'd say you need a new thermostat, sounds like the one you have either sticks or responds slowly. That said, I'm pretty sure it shouldn't do that, even if my diagnosis (guess) is wrong.
lovemycarM35
Nebula Gray
19" wheels
12.3 inch display
Navigation
The00Dustin wrote:Not an expert in the area, but I'd say you need a new thermostat, sounds like the one you have either sticks or responds slowly. That said, I'm pretty sure it shouldn't do that, even if my diagnosis (guess) is wrong.
+1 on that
mcrews
Car: 2002 Q45 Sport
on the 4.5Liter in the Q, there is a themostat up front that opens at 180. then one in the rear that opens at 200.
not sure if you have one or two in the 3.5.
Get the field service manual off this site. Weaqlth of info.
In the 245,000 miles i've NEVER seen my gauge go all the way.....just sayin....
I run a digital obdII scangauge. THe hottest I ever got was 240. And the gauge DID NOT go all the way.
Bruneieddy
Car: 2007 m35X
Going to take it in to the infiniti shop as it is still under warranty. WIll post with results. Thanks all.
Bruneieddy
Car: 2007 m35X
Took to dealer and the issue was an air pocket in the cooling system. Had it flush and looks like it is fixed.
