Engine temp question for you Northern Folk
yodawill2000
Car: 94 Infiniti J30
We just had a nasty cold snap here in the dfw area and Ive noticedMy temp gauge never gets above 2 or 3 ticks from the bottom.No where near where it is on a warmer day. A little below middle.
Is that normal or do I have a stuck open/Missing Thermostat ??
Thank gawd for the heated sets
Q45tech
Thermostats usually degrade after 3-4 years and should be replaced.
The mode is as you describe failure to heat up fast as the rubber surreound has worn and coolant bypasses the element..............ONLY USE OEM NISSAN THERMOSTATS never copies!
yodawill2000
Thanks Q45tech
Will do.
yodawill2000
Never even looked to see where the thermostat is on the J30 .Is it one of those PITA jobs ??Im used to old chevys and it being a 10 minute job
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
I Agree used mine for the first time the other Day It was in the 40s but my coolant temp stayed the same as on a 90 degree day
yodawill2000
Somebody ??Anybody ??Is the T Stat a beotch on our J's ??Been to cold for me to even pop the hood. lol
I dig 105F but this low 30's shizz locks me up.But I need to handle this.She's running super rich the whole way to work.20 mile drive.
ttinfinitiM30
Car: infiniti M30
dont b so sure u need one. im from PA and gotta say durring the winter some cars dont really heat up till after a long hall down the highway. not saying that theres no heat but unless ur runnig the car for a while it wont heat up.
elan
Car: BMW 328I, Had J30 95,
in Siberia we sometimes close the air intake i front and put some warm material under the hood during winter time so the engine warms up faster and stays warm.
yodawill2000
Im leaning towards Techs advice.If its 40 something all is good .If its freezing my gauge barely moves at all.And I have a 20 mile commute on the highway.
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
improperly functioning coolant temperature sensor causes the engine to run rich, clean the contact, and i hope that this would fix one problem, if it does not, then replace the sensor, i think it is about 30$ from the dealer, here is the location of the sensor
now to access the thermostat, it takes longer than the chevys, you have to remove the fan to clear up space to reach it, then remove both aluminum coolant hoses to get to the thermostat (i cant remember the bolt sizes, i think they were a hex, but i have them in the timing belt replacement write-up), here is the location of the thermostat
yodawill2000
Thanx bud ..I doubt its the sensor because the temp gauge stays way low.And on a warmer day it reads accordingly.
Q45tech
2 sensors one for inside gauge [very inaccurate] and one for ecu [very accurate]. Nether fail frequently.
Whereas thermostat out sell the sensors by 200:1.
We always REQUIRE a new thermostat and water pump and misc when we sell a new timing belt replacement. Never frequent enough but better than nothing.
J30Guy612
Car: 1993 Infiniti J30
Hey 95-J30t
Do you have a timing belt replacement write up on this site?
I searched, and checked the how-to's but couldnt find it.
Do you have a link?
95-J30tt
e-mail me and i'll send it to you, my internet provider doesnt give me sufficient space to load the file to the net....
i'll send it to wes (moderator) via e-mail too, i hope that it will make it's way to this site
yodawill2000
Heres one for the ZSame engine me thinx
http://www.ttzd.com/tech/timingbelttech.html
gam30
Car: infiniti m30
spring 55 - 75 degrees my m30 temperature line is just below centersummer 75-90 : temp. line just above centerheat wave last year: about two ticks below top marking w/wo acfall: same as springwinter: about two ticks above bottom line.it does vary with outside temp. and drive speed.i'm city driving.
