LexusGSLux »
https://forums.nicoclub.com/lexusgslux-u308970.html
Thu Sep 14, 2023 6:24 am
It was a Nissan dealer of course. I have no confidence that they read or monitored any scan data. So the 1 temp sensor goes into the head not the block? I think I am going to change the temp sensor just to eliminate 1st.
If it's not the temp sensor, what would be the best way to check for blockage and where it is? Just to explain further, it will be doing ok, then when you get to a point in stop and go, or at a stop light it will just start to climb. I can cut the engine off. Wait until the light changes, then take off and the needle will go back to normal in 3 - 10 sec at most.
This morning after talking with the Nissan dealer and asking pin point questions, I am being told that it's borderline on the exhaust in the coolant test that it could be possibly a crack in the head, head gasket or block crack, some kind of internal engine crack. At 1st test they told me it was not. I got this car back in Feb 2023. Paid very little fort it. I seems to be in good mechanical condition and service. I drove it about 4 hours back to home with no indications and no gauge overheating until it hit rush hour traffic, then discovered this problem.
I have not had time to look into it until now it's been sitting. I 1st changed and drained and refilled the coolant and bled it. Still same problem, so I had a radiator shop bleed it again. Still same problem. It's confirmed that no coolant is leaking any where. I don't see any indication that coolant is in the oil ( i changed it), nor burning or smoking out back. I just can't see a engine crack driving for 3-4 hours with normal temp, then only overheating when coming to stop and go?
Any help or experience with this 3.5 engine would be appreciated. Thanks.
