Engine taken apart pics had rod knock
DammitBobby
Car: S13 91 KA24DET
pic of the rod bearings.
Hmm WTF, numbers 3,4?????
If you look closely you can see the rod bearing shavings in the pan.
pic of the crank rod journal.
fiznat
Car: Grown up :(
Damn man that sucks! Looks like that other motor I got, although you caught it before the bearings got completely destroyed.
Also looks like you were hitting the valves, I would take a look at the valves and check for damage as well.
Sorry to see that dude. How did that happen?
DammitBobby
Car: S13 91 KA24DET
Worn out motor with 166k of abused miles. The timing tensioner was stuck open as well. Added JWT ECU, 740cc injectors,Z32 MAF, Zeitronix wideband and SAFCII. 2 weeks later kocking noise
Hey Fiz you got email give me a call on my cell.Robert.
DammitBobby
Car: S13 91 KA24DET
Pic of the head
WDRacing
head looks good, I imagine my motor will look similar though. I hope I don't need a new friggin crank, or custom bearings after having the crank journals fixed.
DammitBobby
Car: S13 91 KA24DET
I was real suprise not to see any ring land problems. The pistons look fine other then the valves hitting them. I didn`t take the crank out yet. I am going to let the machine shop to that.
DammitBobby
Car: S13 91 KA24DET
You beat me to buying Fiz`s pistons and rods. I probably end up getting the same thing.
Vader
Car: 1998 Trans am, 1970 GTO, 2008 Acura TL-S, 1990 Miata Turbo
Where's the other 4 pistons??
I'm really shocked it wasn't a spun bearing. Who would have thought the timing chain would jump instead.
DammitBobby
Car: S13 91 KA24DET
The other 4 pistons are sitting in a laundry basket!!
